aaP_horacelwhack Why does the panel show that the website’s SSL certificate has expired, even though it seems to have been successfully auto-renewed? Is it because the panel isn’t able to refresh the status automatically?
aaPanel_Kern Hello, If the renewal is successful, it will generally be applied to the website SSL. If it is not successful, it will not be applied. What is your panel version? aaP_horacelwhack
aaPanel_Kern Hello, what is your panel version? We recommend that you check whether you have successfully applied? aaP_horacelwhack
aaPanel_Kern You can try to update to the latest version 7.0.18, then close the SSL of the website, and then apply for SSL. After the records are normal, it will be automatically verified next time. aaP_horacelwhack
