Hello everyone, I want to thank you for this incredible panel, and for the support you give.
I have a problem sending e-mail. according to the server everything is OK. send and receive email fine, but when I try to send to an external account, example: gmail, hotmail, etc the mail is not sent.
I have a moodle platform installed and I can't find a way to send their registration confirmation email to students. thanks
Hola a todos, quiero agradecer por esta increible herramienta, y por el soporte que dan.
Tengo un problema con el envio de e-mail. segun el servidor esta todo OK. envia y recibe email bien, pero cuando trato de enviar a una cuenta externa, ejemplo: gmail, hotmail, etc no se envia el correo.
Tengo instalada una plataforma moodle y no encuentro la manera de enviar su correo de confirmación de registro a los estudiantes. gracias
Oct 2 22:51:09 beeserver postfix/smtp[631168]: 01DE28C002810: to=<beeuniversitycio@gmail.com>, relay=none, delay=199703, delays=199643/0.02/60/0, dsn=4.4.1, status=deferred (connect to alt2.gmail-smtp-in.l.google.com[2607:f8b0:4002:c08::1a]:25: Network is unreachable)
Oct 2 23:04:20 beeserver postfix/smtpd[634591]: warning: No server certs available. TLS won't be enabled
Oct 2 23:04:20 beeserver postfix/smtpd[634591]: connect from localhost[::1]
Oct 2 23:04:20 beeserver postfix/smtpd[634591]: 4C0238C002815: client=localhost[::1], sasl_method=PLAIN, sasl_username=jose@beeteologia.com
Oct 2 23:04:20 beeserver postfix/cleanup[634599]: 4C0238C002815: message-id=<20201002230420.4C0238C002815@beeserver>
Oct 2 23:04:20 beeserver opendkim[295036]: 4C0238C002815: DKIM-Signature field added (s=default, d=beeteologia.com)
Oct 2 23:04:20 beeserver postfix/qmgr[1673]: 4C0238C002815: from=<jose@beeteologia.com>, size=758, nrcpt=1 (queue active)
Oct 2 23:04:20 beeserver postfix/smtpd[634591]: disconnect from localhost[::1] ehlo=1 auth=1 mail=1 rcpt=1 data=1 commands=5
