System Info: OS: Ubuntu 24.04 / VPS Provider: Contabo VPS / aaPanel Version: beta 7.34.0 (2025-04-29)
Issue 2 - Server Restart Problem: When I click "Restart Server" from the Server Home panel, the popup says "Shutting down websites" and then closes, but the server does not actually reboot. I waited over 1 hour and nothing happened. During this time, Cloudflare reported "Web server is down". The VPS itself was still running via SSH. Please check if this is a bug or compatibility issue with Ubuntu 24.04 or Contabo.
Issue 5 - Incorrect IP in Logs: I’m not using any VPN or proxy, but aaPanel shows the server’s own IP as the login/OTP source IP instead of my real client IP. I tried using the “Fix” button but it did not resolve the issue. Please investigate this bug.
Thank you.
