Some Task Not Sending Properly / Not Sending At All.
For Now I Found :
- aaPanel login alarm -> Not Sending Email When I Login Even If I Try On Another Devices Still Not Sending Email.
Another Task Like SSH Login Alarm Sending Successfully and received.
But, SSH login alert Just Sending To First Line In Email List. Example :
if i have 2 email in 2 line:
mail1@example.com
mail2@example.com
the SSH login alert just send to the first email mail1@example.com and mail2@example.com not included
Here's Proofs For Not Sending Alarm Email When Panel Login :
Just That For Now, Idk The rest of the task in alarm settings affected with same problem or not, but with this problem im sure you will check the rest of the task in alarm settings.
Thanks In Advance
