aaP_mashimuro1985 Hi there, I tried to create letsencrypt ssl for domain bill.flyepxress.vn. I config /project/bill_ssl. But when panel already created ssl, folder bill_ssl still empty. Therefore, my domain bill.flyexpress.vn could not access via https. Please take a look from attachment for more info
aaPanel_Kern Hello, You can view this configuration. You can also apply without using the creation of the well-known directory. I have seen that your certificate has expired. Is there any other place that needs to modify the certificate? Is it normal to try to restart nginx once? aaP_mashimuro1985
aaP_mashimuro1985 aaPanel_Kern I've restarted nginx but not luck. I've renew 5 times, ssl was generated as well but still expired. Now I could not apply because of this error
aaP_mashimuro1985 Well, I've re-deploy current ssl and everything is fine now. Thank you very much for all support.
