Hello, I'm having trouble accessing the AAPanel control panel. I can access any website or domain added to the system using https:// without any problems. The problem is that the SSL certificate isn't running on the system's operating port. I changed the system's domain to my company's domain. Everything was working fine. After trying to add another website with the same domain, just with a different port (80), the system's default port, to try to activate SSL on the system panel, the problem started occurring. So, I restarted the entire server and everything worked correctly again except for access to the control panel.
Now I need to manage the system, but at this moment I'm unable to access the panel. When I access it using the server's IP or the domain that was defined as the default, the error is exactly the same. https://i.imgur.com/ELEXLor.png
When I try to access without HTTPS://
https://i.imgur.com/5UKgiTP.png
In other words, I can no longer access the control panel. Is there a way to resolve this issue without having to reinstall the entire system?
