I have provisioned an SSL certificate to be obtained from Let's Encrypt.
I have manually entered the ACME challenge as records on the name server.
Unfortunately, as the expiration date is now within thirty days, the cron task is failing to renew automatically.
Below is the output generated by the cron task. As seen, it is failing to utilize the existing DNS records for approval in the ACME challenge.
Domain Subject:【*.mydomain.xyz】There is a Wildcard Domain Name, and only the DNS Verification Method can be Used for Renewal!
Domain Subject:【*.mydomain.xyz】is not found the dns-api info, try to apply, please wait...
Domain Subject:【*.mydomain.xyz】try to apply result: auth info is not support or not found...
How can I accomplish automated renewal of the certificates?
