rohitarya I have installed SSL for xx.xx.in and its validity is 1 year but on the browser it is showing expired old certificates, please let me know from where i can correct it.
aaPanel_Kern Hello, is it normal to try to access using another browser? Also check whether other places also need to update? rohitarya
rohitarya I had tried it from many browsers also checked it from https://www.geocerts.com/ssl-checker on this test it is also showing ssl expired
aaPanel_Kern We recommend that you check if you use other services? Such as CDN, reverse proxy, etc. Try restarting nginx rohitarya
rohitarya I am not using any type of CDN not any reverse proxy setup also I had tried restarting NGINX too
rohitarya Hi, Problem is resolved actually I just installed Jitsi meet and it override all the config of Nginx after uninstalling Jitsi and Reconfiguring Nginx issue resolved. Thank You for your support
