Klaud how to apply cloudflare ssl in aapanel? i have problem please help when i press connect i can already see my domain on the list please help, now my new site pointing to other site
Klaud now i get the ssl, but it redirect to older sites, tried to disable and reenable but still redirect to older sites, also try to deploy but still same. i try to delete new site and recreate the sites, still redir to older sites. please help
aaPanel_Kern Hello, Is it normal to try restarting nginx, change the browser or close the browser in full and access using traceless mode? Klaud
aaPanel_Kern Please check whether all sites are deploying ssl? Is it normal to try restarting nginx? Check if the domain name records are added? Klaud
Klaud when try to restart nginx this error appear: this site is from another server via one click migration
aaPanel_Kern Are you using one-click migration plugin? Try to find the contents of this file from the old server, create this file on the new server paste the contents of the old server Klaud
aaPanel_Kern Please compress this directory on the old server and then place it on the new server Klaud
Klaud domain name are pointed to server already, i migrate several site, some have the error DNS_PROBE_FINISHED_NXDOMAIN whats really going on here? some working fine some have problems all domain record already pointing to server IP using cloudflare ssl all domain have SSL already nginx can restart normally tried dns only mode and proxy also still have this error DNS_PROBE_FINISHED_NXDOMAIN already tested and waiting for 2 days now
aaPanel_Kern It is recommended that you view DNS information directly on cloudflare official website Klaud
Klaud Yeah already check also, CF dns records are the same, then what makes DNS_PROBE_FINISHED_NXDOMAIN?
