Deprecation Notice in ./libraries/DatabaseInterface.php#518
Unparenthesized a ? b : c ? d : e is deprecated. Use either (a ? b : c) ? d : e or a ? b : (c ? d : e)
Backtrace
./vendor/composer/ClassLoader.php#444: include()
./vendor/composer/ClassLoader.php#322: Composer\Autoload\includeFile(string '/www/server/phpmyadmin/phpmyadmin_5548122ef21add57/vendor/composer/../..//libraries/DatabaseInterface.php')
Composer\Autoload\ClassLoader->loadClass(string 'PMA\libraries\DatabaseInterface')
./libraries/database_interface.inc.php#32: spl_autoload_call(string 'PMA\libraries\DatabaseInterface')
./libraries/common.inc.php#589: include_once(./libraries/database_interface.inc.php)
./server_sql.php#14: require_once(./libraries/common.inc.php)
Deprecation Notice in ./libraries/URL.php#265
Array and string offset access syntax with curly braces is deprecated
Backtrace
./vendor/composer/ClassLoader.php#322: Composer\Autoload\includeFile(string '/www/server/phpmyadmin/phpmyadmin_5548122ef21add57/vendor/composer/../..//libraries/URL.php')
Composer\Autoload\ClassLoader->loadClass(string 'PMA\libraries\URL')
./libraries/Header.php#222: spl_autoload_call(string 'PMA\libraries\URL')
./libraries/Header.php#271: PMA\libraries\Header->getJsParams()
./libraries/Header.php#200: PMA\libraries\Header->getJsParamsCode()
./libraries/Header.php#130: PMA\libraries\Header->_addDefaultScripts()
./libraries/Response.php#94: PMA\libraries\Header->construct()
./libraries/Response.php#128: PMA\libraries\Response->construct()
./libraries/common.inc.php#832: PMA\libraries\Response::getInstance()
Warning in ./libraries/config/FormDisplay.php#661
"continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"?
Backtrace
./vendor/composer/ClassLoader.php#322: Composer\Autoload\includeFile(string '/www/server/phpmyadmin/phpmyadmin_5548122ef21add57/vendor/composer/../..//libraries/config/FormDisplay.php')
Composer\Autoload\ClassLoader->loadClass(string 'PMA\libraries\config\FormDisplay')
./libraries/config/PageSettings.php#76: spl_autoload_call(string 'PMA\libraries\config\FormDisplay')
./libraries/config/PageSettings.php#215: PMA\libraries\config\PageSettings->__construct(string 'Sql_queries')
./server_sql.php#18: PMA\libraries\config\PageSettings::showGroup(string 'Sql_queries')@
