aaP_worktoichoi I have a VPS that is still active! I just checked, and the website is running fine. But when I access AAPanel, it gives an error:
aaPanel_Kern Hello, is the problem solved? If it has not been resolved, you can use the ssh tool to execute the command to check it: curl -k https://www.aapanel.com/script/aapanel_check.sh | bash aaP_worktoichoi
