#centos
yum install -y htop && htop
#debian/ubuntu
apt update
apt install -y htop && htop
or top command analysis
If you can’t analyze website logs, the software store has [Website statistics v2], which can be used to visually check the logs to see which website requests and accesses are currently abnormal. If a large number of requests come in within 1 second or a few seconds, there is a high probability of being hit. Yes, you can install our [nginx waf] plugin to block attacks
Open the Nginx WAF, check whether there is an attacked record, try to adjust the cc defense rule of the Nginx WAF to enhanced mode, and see if the cpu has dropped.
aaP_joseph.quintinita
