when i run display panel error log it shows this
Pls enter command number:22
EXECUTING
File "/www/server/panel/pyenv/lib/python3.12/json/init.py", line 346, in loads
return default_decoder.decode(s)
File "/www/server/panel/pyenv/lib/python3.12/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=w(s, 0).end())
File "/www/server/panel/pyenv/lib/python3.12/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
[2025-12-08 12:41:28][DEBUG] - Traceback (most recent call last):
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/app.py", line 1823, in full_dispatch_request
rv = self.dispatch_request()
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/app.py", line 1799, in dispatch_request
return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args)
File "/www/server/panel/BTPanel/init.py", line 1983, in login
comReturn = common.panelSetup().init()
File "/www/server/panel/class/common.py", line 57, in init
self.__init_panel_asset() # 初始化面板asset资源
File "/www/server/panel/class/common.py", line 32, in init_panel_asset
panel_asset = config_v2().get_panel_asset()
File "/www/server/panel/class_v2/config_v2.py", line 4061, in get_panel_asset
path_data = json.loads(public.readFile(self.panel_asset_config))
[2025-12-08 12:41:29][DEBUG] - Traceback (most recent call last):
File "/www/server/panel/BTPanel/init.py", line 1803, in send_favicon
comReturn = comm.local()
File "/www/server/panel/class/common.py", line 100, in local
result = panelSetup().init()
[2025-12-08 12:49:28][DEBUG] - Traceback (most recent call last):
