Hi,
I have now successfully installed n8n using the Node.js setup as well, but unfortunately I am still facing the same “Connection lost” issue in the editor.
I’ve already shared you the server access details via email earlier.
If possible, could you please check the setup from your side and help identify where the issue might be coming from?
I would really appreciate your help in reviewing the server configuration and pointing out anything that may be causing this problem.
Thank you for your time and support.
