inguide Hello. I'm having trouble renewing my SSL certificate. I have 21 days remaining, but the renewal fails. Why is this happening? .well-known/acme-challenge/T4eij1VxMdzF4KA9EblogfVF9ZYHsXP3QSl0eyFlptw exists. Thank you.
aaPanel_Kern inguide Hello, Does it also show 404 when you access manually? Are you using nginx? You can try restarting nginx.
aaPanel_Kern Thank you for your feedback, it is recommended that you use DNS for verification inguide
aaPanel_Kern Reference documentation: It is recommended that you use the API, otherwise you can only add txt records manually. Manual addition will not automatically renew SSL. https://www.aapanel.com/docs/Function/Domains.html#apply-for-ssl https://www.aapanel.com/docs/Function/php.html#SSL1 inguide
