Dear Support Team,
After upgrading to aaPanel Beta 8.0.1, we are unable to access the system.
We kindly request that you perform the necessary checks and provide an updated release if available.
Additionally, we would appreciate your guidance on the steps required to resolve this issue on our end.
Thank you for your support.
[2026-02-07 01:08:54][DEBUG] - Traceback (most recent call last):
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/app.py", line 1823, in full_dispatch_request
rv = self.dispatch_request()
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/app.py", line 1799, in dispatch_request
return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args)
File "/www/server/panel/BTPanel/__init__.py", line 2091, in login
return render_template('login.html', data=data)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/templating.py", line 147, in render_template
return _render(app, template, context)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/templating.py", line 130, in _render
rv = template.render(context)
File "/www/server/panel/pyenv/lib/python3.12/site-packages/jinja2/environment.py", line 1301, in render
self.environment.handle_exception()
File "/www/server/panel/pyenv/lib/python3.12/site-packages/jinja2/environment.py", line 936, in handle_exception
raise rewrite_traceback_stack(source=source)
File "/www/server/panel/BTPanel/templates/default/login.html", line 87, in top-level template code
opacity: {{ g['panel_theme']['login']['bg_image_opacity'] / 100 }};
TypeError: unsupported operand type(s) for /: 'str' and 'int'
