aaP_hank25x Hello, I was wondering if anyone could tell me how to install and run Ghost in aapanel? I tried to do it with Docker, but it doesn't act properly. Thanks in advance
aaPanel_Kern Hello, What problems did you encounter during operation? It is recommended that you check the corresponding logs aaP_hank25x
aaP_hank25x aaPanel_Kern Admin login would not work, due to proxy path. When I thought I had it fixed, I just ended up with a 502 Nginx error. I'm reinstalling it to try again
aaP_hank25x aaPanel_Kern Thank you for checking. I haven't had a chance to get back into it yet, but I will post updates when I do. Thanks again
