mhosseint Hello, I installed the Google Cloud Storage plugin and after that this error is displayed in the panel. I deleted the plugin and also clicked on the fix button and rebooted the server but the problem did not get resolved: Please fix this problem. Thanks.
aaPanel_Kern Hello, Can fix it by executing this command to update and repair it to the latest version? mv /www/server/panel/pyenv /www/server/panel/pyenv_bak rm -f /tmp/update_to7.pl && curl -k https://node.aapanel.com/install/update_panel_en.sh | bash mhosseint
mhosseint Yes, thank you very much. The problem and error were resolved by executing these commands. Only then did fail2ban have a problem, which was resolved by deleting the plugin and reinstalling and configuring it again.
