--2026-07-06 19:05:41-- https://node.aapanel.com/install/3/memcached.sh
Resolving node.aapanel.com (node.aapanel.com)... 104.26.11.85, 104.26.10.85, 172.67.73.28, ...
Connecting to node.aapanel.com (node.aapanel.com)|104.26.11.85|:443... connected.
Length: 10264 (10K) [application/octet-stream]
Saving to: ‘memcached.sh’
0K .......... 100% 12.1M=0.001s
2026-07-06 19:05:42 (12.1 MB/s) - ‘memcached.sh’ saved [10264/10264]
selecting download node...
https://cf1-node.aapanel.com
|-INFO: Node_Url: node.aapanel.com
--2026-07-06 19:06:02-- https://node.aapanel.com/install/public.sh
Resolving node.aapanel.com (node.aapanel.com)... 104.26.10.85, 104.26.11.85, 172.67.73.28, ...
Connecting to node.aapanel.com (node.aapanel.com)|104.26.10.85|:443... connected.
Length: 5745 (5.6K) [application/octet-stream]
Saving to: ‘/www/server/panel/install/public.sh’
0K ..... 100% 48.4M=0s
2026-07-06 19:06:02 (48.4 MB/s) - ‘/www/server/panel/install/public.sh’ saved [5745/5745]
Reading package lists...
Building dependency tree...
Reading state information...
Package 'memcached' is not installed, so not removed
The following packages were automatically installed and are no longer required:
libgnutls-dane0 libunbound8
Use 'apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
libsasl2-2 is already the newest version (2.1.28+dfsg-10).
libsasl2-dev is already the newest version (2.1.28+dfsg-10).
libevent-dev is already the newest version (2.1.12-stable-8).
php-. not install, Plese select other version!
--2026-07-06 19:06:23-- https://cf1-node.aapanel.com/tools/check.sh
Resolving cf1-node.aapanel.com (cf1-node.aapanel.com)... 104.26.10.85, 104.26.11.85, 172.67.73.28, ...
Connecting to cf1-node.aapanel.com (cf1-node.aapanel.com)|104.26.10.85|:443... connected.
Length: 565 [application/octet-stream]
Saving to: ‘/www/server/panel/install/check.sh’
0K 100% 144K=0.004s
2026-07-06 19:06:24 (144 KB/s) - ‘/www/server/panel/install/check.sh’ saved [565/565]
