aaP_Vibhanshu https://prnt.sc/EvTj9PIQsGY6 Facing this issue, how to fix? Billionmail in docker is not working
aaPanel_Kern Hello, It is recommended that you check if the network is normal? curl -v https://www.aapanel.com ping www.aapanel.com -c 5 ping google.com -c 5 curl -v http://www.aapanel.com aaP_Vibhanshu
aaP_cris_1369 im with this problem trying to manually migrate all mail, from mail app to billion even with added ip and hostname
aaPanel_Kern These are optional. Can't they be saved? Should the panel use SSL for access? aaP_cris_1369
aaP_cris_1369 No. Cant save any type on sso aapanel with billionmail, but in billionmail web ui i can save. Even add new domains. Get another issue too. Cant pull the tls certificates from aapanel powerdns
aaPanel_Kern Hello, Is SSL enabled on the panel? Is there any more information you can provide us with? aaP_cris_1369
aaP_cris_1369 aaPanel_Kern yes, enabled with * wildcard, but why cant pull the tls certificates on the aapanel domains?
