i did run this command on all the inaccessible panels and same response accros all of them:
Bt-Panel (pid 4501) already running
Bt-Task (pid 4490) already running
webserver 4532 root 7u IPv4 36919 0t0 TCP *:7800 (LISTEN)
Getting server ip, Please wait...
aaPanel port external network xxxx 7800 test access is normal
SSL is not enabled, please use HTTP access
aaPanel Internet IPv4 Address: xxxx
aaPanel Internal Address: xxxx
When sharing, please be careful to hide your IP address
Server internal 127.0.0.1 test access is normal
