Hi
II like aaPanel. It easy to use
But i see following problems:
Example: to run open cart i have to change chmod 777 -R myDomainServerFolder. in other cases not working installation and site. if i return chmod 644 to config.php after instalation - site stop working i see this problem with most of the scripts that i test on aa Panel. in fact most of the sites works ok only when chmod 777 for all folders but this is very risky
Please tell me how to protect proper my site with chmod? N.B. On other panels i didnt see such problem. Can you give full description step by step how to protect opencart folders
