aaPanel_Jose lnhax Please check whether the database is running Try to create a test database in the database to see if it is normal Check the database recycle bin to see if there is an undeleted database with the same name
lnhax i have checked it all the thing 1 database running 2 database runing with other sites 3 recycle bin is also clean still not working
Dhanamerdeka lnhax mysql installed? on past i have this issue when i checked mysql not running and on some try... i not even install it lol i hope you can have the solution soon
aaPanel_Jose lnhax This problem can also occur if the mysql root password on the panel is incorrect, please try to reset the mysql root password
