sanjard Hello, i am using aapanel on Ubuntu in my VPS and now my aapanel login link do not work anymore. than i try go to this login link i am getting error: This site can’t be reached :https://prnt.sc/vz5hkd I tried all BT commands in SSH console, but nothing happened. Reinstall panel command not working.. Can someone help me solve this problem?
aaPanel_Jose sanjard Check if your panel port is listening netstat -ntulp Try to log in after restarting the panel bt restart Use the installation command to overwrite the installation panel (data will not be lost)
sanjard After command netstat -ntulp i am getting https://i.gyazo.com/19e3da1b742cf34c6f0fd38500926bdf.png but i do not understand what is mean. Sorry i am newbe, this is first time i use Linux VPS with aapanel. Bt restart command not helping. Install comman also not working. i am getting this: https://i.gyazo.com/98f9316ee48278a232d7ddd765447908.png Can you help me?
aaPanel_Jose sanjard Please try to change your dns server to 8.8.8.8 before executing the installation command In the result of netstat -ntulp, it seems that your panel is not activated use bt start to start the panel
