Last metadata expiration check: 0:18:25 ago on Fri 22 Jan 2021 08:52:39 AM CET.
No match for argument: lsphp80-mysqlnd
Error: Unable to find a match: lsphp80-mysqlnd
Last metadata expiration check: 0:18:27 ago on Fri 22 Jan 2021 08:52:39 AM CET.
No match for argument: lsphp80-sqlite3
Error: Unable to find a match: lsphp80-sqlite3
Last metadata expiration check: 0:18:28 ago on Fri 22 Jan 2021 08:52:39 AM CET.
No match for argument: lsphp80-zip
Error: Unable to find a match: lsphp80-zip
Last metadata expiration check: 0:18:29 ago on Fri 22 Jan 2021 08:52:39 AM CET.
No match for argument: lsphp80-curl
Error: Unable to find a match: lsphp80-curl
Last metadata expiration check: 0:18:30 ago on Fri 22 Jan 2021 08:52:39 AM CET.
Last metadata expiration check: 0:18:32 ago on Fri 22 Jan 2021 08:52:39 AM CET.
No match for argument: lsphp80-common
Error: Unable to find a match: lsphp80-common
Last metadata expiration check: 0:18:33 ago on Fri 22 Jan 2021 08:52:39 AM CET.
No match for argument: lsphp80-gd
Error: Unable to find a match: lsphp80-gd
Last metadata expiration check: 0:18:34 ago on Fri 22 Jan 2021 08:52:39 AM CET.
No match for argument: lsphp80-process
Error: Unable to find a match: lsphp80-process
Last metadata expiration check: 0:18:36 ago on Fri 22 Jan 2021 08:52:39 AM CET.
No match for argument: lsphp80-mbstring
Error: Unable to find a match: lsphp80-mbstring
Last metadata expiration check: 0:18:37 ago on Fri 22 Jan 2021 08:52:39 AM CET.
No match for argument: lsphp80-xml
Error: Unable to find a match: lsphp80-xml
Last metadata expiration check: 0:18:38 ago on Fri 22 Jan 2021 08:52:39 AM CET.
No match for argument: lsphp80-mcrypt
Error: Unable to find a match: lsphp80-mcrypt
Last metadata expiration check: 0:18:39 ago on Fri 22 Jan 2021 08:52:39 AM CET.
No match for argument: lsphp80-pdo
Error: Unable to find a match: lsphp80-pdo
Last metadata expiration check: 0:18:41 ago on Fri 22 Jan 2021 08:52:39 AM CET.
No match for argument: lsphp80-imap
Error: Unable to find a match: lsphp80-imap
Last metadata expiration check: 0:18:42 ago on Fri 22 Jan 2021 08:52:39 AM CET.
Last metadata expiration check: 0:18:43 ago on Fri 22 Jan 2021 08:52:39 AM CET.
Last metadata expiration check: 0:18:44 ago on Fri 22 Jan 2021 08:52:39 AM CET.
Last metadata expiration check: 0:18:45 ago on Fri 22 Jan 2021 08:52:39 AM CET.
Last metadata expiration check: 0:18:47 ago on Fri 22 Jan 2021 08:52:39 AM CET.
Last metadata expiration check: 0:18:48 ago on Fri 22 Jan 2021 08:52:39 AM CET.
Last metadata expiration check: 0:18:49 ago on Fri 22 Jan 2021 08:52:39 AM CET.
Last metadata expiration check: 0:18:51 ago on Fri 22 Jan 2021 08:52:39 AM CET.
Last metadata expiration check: 0:18:52 ago on Fri 22 Jan 2021 08:52:39 AM CET.
Last metadata expiration check: 0:18:53 ago on Fri 22 Jan 2021 08:52:39 AM CET.
Last metadata expiration check: 0:18:54 ago on Fri 22 Jan 2021 08:52:39 AM CET.
Last metadata expiration check: 0:18:56 ago on Fri 22 Jan 2021 08:52:39 AM CET.
Last metadata expiration check: 0:18:57 ago on Fri 22 Jan 2021 08:52:39 AM CET.
Last metadata expiration check: 0:18:58 ago on Fri 22 Jan 2021 08:52:39 AM CET.
Last metadata expiration check: 0:18:59 ago on Fri 22 Jan 2021 08:52:39 AM CET.
Last metadata expiration check: 0:19:01 ago on Fri 22 Jan 2021 08:52:39 AM CET.
Last metadata expiration check: 0:19:02 ago on Fri 22 Jan 2021 08:52:39 AM CET.
mv: cannot stat '/usr/local/lsws/lsphp80/etc/php.ini': No such file or directory
/usr/local/lsws/lsphp80/etc/php.ini: No such file or directory
mv: cannot stat '/usr/local/lsws/lsphp80/etc/php.ini_old': No such file or directory
sed: can't read /usr/local/lsws/lsphp80/etc/php.ini: No such file or directory
map default *
grep: /www/server/panel/vhost/nginx/phpmyadmin.conf: No such file or directory
[OK] litespeed: pid=122350.
