aaPanel_thisyear Hello, open the mongodb log and restart it to see if there is any error. If there is any error information, paste a screenshot of the error information
aapanel_power /www/server/mongodb/log/config.log Hello, brother, you can read the error message in this file, here is the reason why MongoDB cannot start
vinpro aapanel_power I tried go to "/www/server/mongodb/log/config.log" but it is empty directory. How to run start mongodb on Terminal to see error?
aaP_tangdinhvu aapanel_power bro can you help me? i want to use mongodb but i cant start after install
ddiaz2380 vinpro I have the same problem, I reinstall it and it still does not start, and the log does not show anything. Could you solve it?
aaP_jeanvs23 Hi to everybody this issue is related to the root user have a look if you have disabled root user
aaPanel_Kern NoobRogue Hello, does the installation of mongodb show any error content? Is there any error displayed on startup? Is your system aarch64? Check out the installation process: Start command: /etc/init.d/mongodb start View system architecture: uname -a
