aapanel_sniper aaP_thangjin203 Good afternoon, after adding a website, you need to resolve your domain name to the server and allow port 80 to access.
aapanel_sniper aaP_thangjin203 In the server, use aapanel’s ‘security’-’accept port’-’80’-’open’ After this, you need to go to the vps server merchant to let it go. For example, google cloud:
aapanel_sniper aaP_thangjin203 Hello, according to the description in the official document, the current 522 error is that the source station cannot be connected. The solution to this method requires port 80 communication.
aapanel_sniper aaP_thangjin203 Sorry, I don’t have an aws server, so I can’t operate screenshots. In theory, the process is similar, set in the firewall of the vps instance.
warra its pointing to the wrong ip on your end (example, vps) and you may need to change it in the DNS settings in cloudflare if you are using them for DNS, or wherever it is.
