edgar2031
Please switch to compatible phpmyadmin and php versions.
It is recommended to use phpmyadmin5.0 and php7.4.
Compatibility of the following versions:
phpMyAdmin5.0.0 Current version compatible with PHP 5.5 to 7.4 and MySQL 5.5 and newer.
phpMyAdmin4.9.0 Current version compatible with PHP 5.5 to 7.3 and MySQL 5.5 and newer.
phpMyAdmin4.8.0 Older version compatible with PHP 5.5 to 7.2 and MySQL 5.5 and newer. Was supported until June 4, 2019.
phpMyAdmin4.6.0-4.7.0 Older version compatible with PHP 5.5 to 7.1 and MySQL 5.5 and newer. Was supported until April 1, 2017.
phpMyAdmin4.5.0 Older version compatible with PHP 5.5 to 7.0 and MySQL 5.5. Was supported until April 1, 2016.
phpMyAdmin4.4.0 Older version compatible with PHP 5.3.7 to 7.0 and MySQL 5.5. Was supported until October 1, 2016.
phpMyAdmin4.1.0-4.3.0 Older version compatible with PHP 5.3 and MySQL 5.5. Was supported until October 1, 2015.
phpMyAdmin4.0.0 Older version compatible with PHP 5.2 and MySQL 5. Does not support PHP 5.5 or newer. Was supported until April 1, 2017.
