Hi, im having this error starting docker
Current status:On
Sorry, something went wrong:
raise NotFound()
chunked=chunked,
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 394, in make_request
conn.request(method, url, **httplib_request_kw)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 1277, in request
self.send_request(method, url, body, headers, encode_chunked)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 1323, in send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 1272, in endheaders
self.send_output(message_body, encode_chunked=encode_chunked)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 1032, in send_output
self.send(msg)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 972, in send
self.connect()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/docker/transport/unixconn.py", line 43, in connect
sock.connect(self.unix_socket)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/socketcommon.py", line 628, in connect
raise _SocketError(result, strerror(result))
FileNotFoundError: [Errno 2] No such file or directory
timeout=timeout
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/retry.py", line 531, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/packages/six.py", line 734, in reraise
chunked=chunked,
self.send(msg)
self.connect()
urllib3.exceptions.ProtocolError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
File "/www/server/panel/pyenv/lib/python3.7/site-packages/docker/api/client.py", line 214, in retrieve_server_version
return self.version(api_version=False)["ApiVersion"]
File "/www/server/panel/pyenv/lib/python3.7/site-packages/docker/api/daemon.py", line 181, in version
return self.result(self._get(url), json=True)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/docker/utils/decorators.py", line 46, in inner
return f(self, *args, **kwargs)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/docker/api/client.py", line 237, in get
return self.get(url, **self.set_request_timeout(kwargs))
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 555, in get
return self.request('GET', url, **kwargs)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/adapters.py", line 498, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
File "class/panelPlugin.py", line 1981, in a
return eval(execStr)
File "", line 1, in
File "plugin/docker/docker_main.py", line 662, in service_admin
self.__docker = docker.from_env()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/docker/client.py", line 101, in from_env
kwargs_from_env(kwargs)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/docker/client.py", line 45, in init
self.api = APIClient(*args, **kwargs)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/docker/api/client.py", line 197, in init
self.version = self.retrieve_server_version()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/docker/api/client.py", line 222, in _retrieve_server_version
'Error while fetching server API version: {0}'.format(e)
docker.errors.DockerException: Error while fetching server API version: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
