TEZO hello. after last update i have problem, i cann't author in admin panel but my all website still working good
aaPanel_thisyear TEZO Hello, panel and website are two independent services. Even if the panel is hung, it will not affect the normal access of the website. Server command line, execute the following command to repair aapanel. bt 16
TEZO i fix it https://domain:port/site - working and other section working good, problem was dashboard plugins module for fix you need disable all plugin on dashboard url for disable plugins on dashboard: https://domain:port/soft
