norge im trying to remember how to create php site in aapanel, i have the php files sites already written but do i do default url rewrite? im pretty sure i got namecheap setup correctly. it would be helpful if someone could post reply with pictures thanks @aaPanel_Jose
toaitran In the site manager, you can select the rewrite route for your site, also, if you're using frameworks like laravel, phalcon, you should select the folder of the app to run. Like this:
