aaP_thiagomoisesaraujo Hello Guys, Could you help me? I stopped having access to the Admin Panel, I can access the Openlitespeed Panel plus access to aaPanel I can no longer access, displays the error "ERR_CONNECTION_RESET" could someone help me?
aaPanel_thisyear aaP_thiagomoisesaraujo Hello, if you can no longer access the aapanel panel, the server command line executes the following command screenshot to see if there is an error /etc/init.d/bt start
aaPanel_Jose aaP_thiagomoisesaraujo I found that https is enabled on your panel, please use https to access https://your_ip:8881
