irahmanyzi
Hello sir, according to your description, probably the php version is not selected right, the panel is able to install more than one version of php, so it did not do the environment variable for php, you can use it like this: the following example with php7.4 version
The script is as follows,hope it will help you
/www/server/php/74/bin/php/www/wwwroot/mywebsite.com/application/artisan schedule:run >> /dev/null 2>&1
