configure: error: Package requirements (libcurl >= 7.15.5) were not met:
No package 'libcurl' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables CURL_CFLAGS
and CURL_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
make: *** No rule to make target 'install'. Stop.
Debian GNU/Linux 10
\l
Bit:64 Mem:3743M Core:4 gcc:8.3.0 cmake:3.13.4
Linux 4.19.0-16-amd64 x86_64
ERROR: php-7.4.20 install failed.
Please submit to https://www.aapanel.com/forum for help
