Exception in thread Thread-6:
File "/www/server/panel/pyenv/lib/python3.7/threading.py", line 926, in bootstrap_inner
self.run()
File "/www/server/panel/pyenv/lib/python3.7/threading.py", line 870, in run
self.target(*self.args, **self.kwargs)
TypeError: httpGet() takes from 1 to 2 positional arguments but 3 were given
<gevent.socket3.socket at 0x7fcb5b14b360 object, fd=9, family=2, type=1, proto=0>: Invalid HTTP method: '\x04\x01\x00P[É4B0\x00'
<gevent.socket3.socket at 0x7fcb5964e670 object, fd=8, family=2, type=1, proto=0>: Invalid HTTP method: '\x04\x01\x00P[É4B0\x00'
<gevent.socket3.socket at 0x7fcb5964ede0 object, fd=9, family=2, type=1, proto=0>: Invalid HTTP method: '\x05\x01\x00'
File "src/gevent/greenlet.py", line 906, in gevent.gevent_cgreenlet.Greenlet.run
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/baseserver.py", line 34, in handle_and_close_when_done
return handle(*args_tuple)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/pywsgi.py", line 1577, in handle
handler.handle()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/pywsgi.py", line 471, in handle
self.socket.sendall(response_body)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/socketcommon.py", line 699, in sendall
return sendall(self, data_memory, flags)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/socketcommon.py", line 409, in sendall
timeleft = __send_chunk(socket, chunk, flags, timeleft, end)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/socketcommon.py", line 338, in __send_chunk
data_sent += socket.send(chunk, flags)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/socketcommon.py", line 722, in send
return self.sock.send(data, flags)
BrokenPipeError: [Errno 32] Broken pipe
2021-08-26T19:11:05Z <Greenlet at 0x7fcb5acd2170: handle_and_close_when_done(<bound method WSGIServer.handle of <WSGIServer at , <bound method StreamServer.do_close of <WSGIServer, (<gevent.socket3.socket [closed] at 0x7fcb5964ede)> failed with BrokenPipeError
<gevent.socket3.socket at 0x7fcb595cfbb0 object, fd=7, family=2, type=1, proto=0>: Invalid HTTP method: '\x05\x01\x00'
handler.handle()
2021-08-26T19:11:15Z <Greenlet at 0x7fcb5acd2170: handle_and_close_when_done(<bound method WSGIServer.handle of <WSGIServer at , <bound method StreamServer.do_close of <WSGIServer, (<gevent.socket3.socket [closed] at 0x7fcb595cfbb)> failed with BrokenPipeError
<gevent.socket3.socket at 0x7fcb594c3520 object, fd=7, family=2, type=1, proto=0>: Invalid HTTP method: '\x16\x03\x01\x00{\x01\x00\x00w\x03\x03\t\x89\x88\x13\x19òÑÊ0Ià\x10²â´ñ±ksôª\x9a\x1fÏ>\x80\x86\x1e§ñ\x9a\x00\x00\x1aÀ/À+À\x11À\x07À\x13À\tÀ\x14À\n'
<gevent._socket3.socket at 0x7fcb5ad44670 object, fd=7, family=2, type=1, proto=0>: Invalid HTTP method: '4\n'
<gevent._socket3.socket at 0x7fcb5ad44670 object, fd=7, family=2, type=1, proto=0>: Expected GET method: "\x16\x03\x01\x00{\x01\x00\x00w\x03\x03)Ô\x13/\x08º|÷\x1awÖ\x0fö;èñúü.âpô\x12\xad\x81Ngy'7\x00\x00\x1aÀ/À+À\x11À\x07À\x13À\tÀ\x14À\n"
<gevent.socket3.socket at 0x7fcb5ab63d00 object, fd=14, family=2, type=1, proto=0>: Invalid HTTP method: "\x16\x03\x01\x00ä\x01\x00\x00à\x03\x03\x89¹Y{\x99éÕW\x91þ\x88-3\x0b1\x04C\x81\x8cv\x85\x92Êúc÷\x13°K3\x00\x00hÌ\x14Ì\x13À/À+À0À,À\x11À\x07À'À#À\x13À\tÀ(À$À\x14À\n"
<gevent.socket3.socket at 0x7fcb600d2f30 object, fd=14, family=2, type=1, proto=0>: Invalid http version: "\x16\x03\x01\x00{\x01\x00\x00w\x03\x03±u´pÃr\x00\x01Ï ;+E\x83=¯\x14'r}áß\x18Ý\x88¤Õ%0zN\x00\x00\x1aÀ/À+À\x11À\x07À\x13À\tÀ\x14À\n"
<gevent.socket3.socket at 0x7fcb5b14b750 object, fd=7, family=2, type=1, proto=0>: Invalid HTTP method: '\x04\x01\x00PWì\x10\x170\x00'
File "src/gevent/greenlet.py", line 906, in gevent._gevent_cgreenlet.Greenlet.run
handler.handle()
2021-08-27T19:23:18Z <Greenlet at 0x7fcb60fdeef0: handle_and_close_when_done(<bound method WSGIServer.handle of <WSGIServer at , <bound method StreamServer.do_close of <WSGIServer, (<gevent.socket3.socket [closed] at 0x7fcb5b14b75)> failed with BrokenPipeError
<gevent.socket3.socket at 0x7fcb5b14b910 object, fd=8, family=2, type=1, proto=0>: Invalid HTTP method: '\x04\x01\x00P²\x80"c0\x00'
<gevent.socket3.socket at 0x7fcb58161360 object, fd=8, family=2, type=1, proto=0>: Invalid HTTP method: '\x05\x01\x00'
handler.handle()
2021-08-27T19:23:28Z <Greenlet at 0x7fcb5acd23b0: handle_and_close_when_done(<bound method WSGIServer.handle of <WSGIServer at , <bound method StreamServer.do_close of <WSGIServer, (<gevent.socket3.socket [closed] at 0x7fcb5816136)> failed with BrokenPipeError
