wormhole You should add 1-click install for LOMP (OpenLiteSpeed). The best for DDOS. The only web server that automatically caches files in RAM. Thank you in advance.
DimmmCom As I understand it, it means setting up the environment when you first start the panel. Dialog box where you can specify the versions of OLS, MySQL, PHP, etc.
Stealth +1 for OLS fast installing. I missing it 1-2 years from aaPanel. The most ram get free when using OLS.
