Hello, I have tried to install the Google Drive plugin, but it causes an error:
`Sorry, something went wrong:
raise NotFound()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 157, in new_conn
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/connection.py", line 84, in create_connection
raise err
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/connection.py", line 74, in create_connection
sock.connect(sa)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/_socket3.py", line 335, in connect
raise error(err, strerror(err))
ConnectionRefusedError: [Errno 111] Connection refused
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 672, in urlopen
chunked=chunked,
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 387, in make_request
conn.request(method, url, **httplib_request_kw)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 1262, in request
self.send_request(method, url, body, headers, encode_chunked)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 1308, in send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 1257, in endheaders
self.send_output(message_body, encode_chunked=encode_chunked)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 1028, in send_output
self.send(msg)
File "/www/server/panel/pyenv/lib/python3.7/http/client.py", line 968, in send
self.connect()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 184, in connect
conn = self.new_conn()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 169, in _new_conn
urllib3.exceptions.NewConnectionError: : Failed to establish a new connection: [Errno 111] Connection refused
timeout=timeout
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 720, in urlopen
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/retry.py", line 436, in increment
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='localhost', port=44165): Max retries exceeded with url: /?state=Sv5iQPkyBGRPKMvlM9kzjrchX2uENa&code=4/0AX4XfWgz9JzY9wGR3cCy5OXT9M7dvgoUw8vSELvXxIvBouWZteuCdgmydJYR0uQRRLj78w&scope=https://www.googleapis.com/auth/drive.file (Caused by NewConnectionError(': Failed to establish a new connection: [Errno 111] Connection refused'))
File "class/panelPlugin.py", line 2095, in a
return eval(execStr)
File "", line 1, in
File "/www/server/panel/plugin/gdrive/gdrive_main.py", line 200, in set_auth_url
requests.get(get.url)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 75, in get
return request('get', url, params=params, **kwargs)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 60, in request
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
requests.exceptions.ConnectionError: HTTPConnectionPool(host='localhost', port=44165): Max retries exceeded with url: /?state=Sv5iQPkyBGRPKMvlM9kzjrchX2uENa&code=4/0AX4XfWgz9JzY9wGR3cCy5OXT9M7dvgoUw8vSELvXxIvBouWZteuCdgmydJYR0uQRRLj78w&scope=https://www.googleapis.com/auth/drive.file (Caused by NewConnectionError(': Failed to establish a new connection: [Errno 111] Connection refused'))`
PS: The port is opened.
