when you add a nodejs app (express, next, nuxt, etc) it adds somthing like this to your virtual host config file:
<VirtualHost *:80>
ServerAdmin admin@something
DocumentRoot "/www/wwwroot/something.com"
ServerName 80.ehsandevs
ServerAlias ehsandevs.ir
#errorDocument 404 /404.html
ErrorLog "/www/wwwlogs/something-error_log"
CustomLog "/www/wwwlogs/something-access_log" combined
#HTTP_TO_HTTPS_START
<IfModule mod_rewrite.c>
RewriteEngine on
RewriteCond %{SERVER_PORT} !^443$
RewriteRule (.*) https://%{SERVER_NAME}$1 [L,R=301]
</IfModule>
#HTTP_TO_HTTPS_END
#DENY FILES
<Files ~ (\.user.ini|\.htaccess|\.git|\.svn|\.project|LICENSE|README.md|package.json|package-lock.json|\.env)$>
Order allow,deny
Deny from all
</Files>
#SSL
ProxyPass /.well-known/ !
#HTTP reverse proxy related settings begin >>>
<IfModule mod_proxy.c>
ProxyRequests Off
SSLProxyEngine on
ProxyPass / http://127.0.0.1:3000/
ProxyPassReverse / http://127.0.0.1:3000/
</IfModule>
#End of HTTP reverse proxy related settings <<<
</VirtualHost>
(my web server is apache but if you got this problem in nginx it might give you the idea)
and when you enable SSL, it adds below code (ths previous code still exists and not replaced)
<VirtualHost *:443>
ServerAdmin webmaster@example.com
DocumentRoot "/www/wwwroot/somthing.ir/"
ServerName SSL.somthing
ServerAlias somthing.com
ErrorLog "/www/wwwlogs/somthing-error_log"
CustomLog "/www/wwwlogs/somthing-access_log" combined
#SSL
SSLEngine On
SSLCertificateFile /www/server/panel/vhost/cert/somthing/fullchain.pem
SSLCertificateKeyFile /www/server/panel/vhost/cert/somthing/privkey.pem
SSLCipherSuite EECDH+CHACHA20:EECDH+CHACHA20-draft:EECDH+AES128:RSA+AES128:EECDH+AES256:RSA+AES256:EECDH+3DES:RSA+3DES:!MD5
SSLProtocol All -SSLv2 -SSLv3 -TLSv1
SSLHonorCipherOrder On
#PHP
<FilesMatch \.php$>
SetHandler "proxy:unix:/tmp/php-cgi-00.sock|fcgi://localhost"
</FilesMatch>
#DENY FILES
<Files ~ (\.user.ini|\.htaccess|\.git|\.svn|\.project|LICENSE|README.md)$>
Order allow,deny
Deny from all
</Files>
#PATH
<Directory "/www/wwwroot/somthing/">
SetOutputFilter DEFLATE
Options FollowSymLinks
AllowOverride All
Require all granted
DirectoryIndex index.php index.html index.htm default.php default.html default.htm
</Directory>
</VirtualHost>
just notice the #PATH section.
man, this is a php thing. This problem is just a bug with aaPanel
you just need to replace this section in your VirtualHost *:443 section:
#PATH
<Directory "/www/wwwroot/ehsandevs.ir/">
AllowOverride All
Require all granted
</Directory>
with this:
ProxyRequests Off
SSLProxyEngine on
</IfModule>
(its just copied from VirtualHost *:80 section)
