aquilamendes Dear, I have a new VPS running aaPanel (CentOS 7) the API key + API Limit is already configured and even so I can't enable SSL for the site, see the print below the error, what can it be? @aaPanel_Jose @aaPanel_Captain
aaPanel_Captain Hello, I have prompted you that Cloudflare already has TXT record value, you need to go to Cloudflare to set to remove TXT record value
aquilamendes aaPanel_Captain I figured it was that doing some deeper research and I removed it in cloudflare and redid the SSL installation process and it was, thanks.
