I have problem installing mysql 5.6 / 5.7
get this error
Scanning dependencies of target bug25714
[ 81%] Building C object testclients/CMakeFiles/bug25714.dir/bug25714.c.o
[ 81%] Linking CXX executable bug25714
[ 81%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/abstract_dump_task.cc.o
[ 81%] Built target bug25714
[ 81%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/abstract_mysql_chain_element_extension.cc.o
Scanning dependencies of target mysql_client_test
[ 81%] Building C object testclients/CMakeFiles/mysql_client_test.dir/mysql_client_test.c.o
[ 81%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/abstract_object_reader_wrapper.cc.o
[ 81%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/abstract_output_writer_wrapper.cc.o
[ 81%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/abstract_plain_sql_object.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/abstract_plain_sql_object_dump_task.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/abstract_progress_reporter.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/abstract_progress_watcher.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/abstract_simple_dump_task.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/abstract_table_dump_task.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/chain_data.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/composite_message_handler.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/compression_lz4_writer.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/compression_zlib_writer.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/database.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/database_end_dump_task.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/database_start_dump_task.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/dump_end_dump_task.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/dump_start_dump_task.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/event_scheduler_event.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/field.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/file_writer.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/i_chain_element.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/i_connection_provider.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/i_crawler.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/i_data_formatter.cc.o
[ 82%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/i_data_formatter_wrapper.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/i_data_object.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/i_dump_task.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/i_object_reader.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/i_object_reader_wrapper.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/i_output_writer.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/i_output_writer_wrapper.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/i_progress_reporter.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/i_progress_watcher.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/item_processing_data.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/mysql_chain_element_options.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/mysql_crawler.cc.o
[ 83%] Linking CXX executable mysql_client_test
[ 83%] Built target mysql_client_test
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/mysql_field.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/mysql_function.cc.o
Scanning dependencies of target libmysql_api_test
[ 83%] Building C object libmysql/CMakeFiles/libmysql_api_test.dir/api_test.c.o
[ 83%] Linking CXX executable libmysql_api_test
[ 83%] Built target libmysql_api_test
Scanning dependencies of target mysql_upgrade
[ 83%] Building CXX object client/CMakeFiles/mysql_upgrade.dir/upgrade/program.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/mysql_object_reader.cc.o
[ 83%] Linking CXX executable mysql_upgrade
[ 83%] Built target mysql_upgrade
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/mysql_object_reader_options.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/mysqldump_tool_chain_maker.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/mysqldump_tool_chain_maker_options.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/object_filter.cc.o
CMakeFiles/Makefile2:7806: recipe for target 'sql/CMakeFiles/sql.dir/all' failed
make[1]: *** [sql/CMakeFiles/sql.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/object_queue.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/pattern_matcher.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/privilege.cc.o
[ 83%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/row.cc.o
[ 84%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/row_group_dump_task.cc.o
[ 84%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/simple_id_generator.cc.o
CMakeFiles/Makefile2:8398: recipe for target 'libmysqld/CMakeFiles/sql_embedded.dir/all' failed
make[1]: *** [libmysqld/CMakeFiles/sql_embedded.dir/all] Error 2
[ 84%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/single_transaction_connection_provider.cc.o
[ 84%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/sql_formatter.cc.o
[ 84%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/sql_formatter_options.cc.o
[ 84%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/standard_progress_watcher.cc.o
[ 84%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/standard_writer.cc.o
[ 84%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/stored_procedure.cc.o
[ 84%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/table.cc.o
[ 84%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/table_deferred_indexes_dump_task.cc.o
[ 84%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/table_definition_dump_task.cc.o
[ 84%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/table_rows_dump_task.cc.o
[ 84%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/tables_definition_ready_dump_task.cc.o
[ 84%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/thread.cc.o
[ 84%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/thread_group.cc.o
[ 84%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/thread_specific_connection_provider.cc.o
[ 84%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/trigger.cc.o
[ 84%] Building CXX object client/dump/CMakeFiles/mysqlpump_lib.dir/view.cc.o
[ 84%] Building C object client/dump/CMakeFiles/mysqlpump_lib.dir/__/__/sql-common/my_user.c.o
[ 84%] Linking CXX static library ../../archive_output_directory/libmysqlpump_lib.a
[ 84%] Built target mysqlpump_lib
Makefile:162: recipe for target 'all' failed
make: *** [all] Error 2
Ubuntu 18.04.3 LTS
\l
Bit:64 Mem:3945M Core:6 gcc:7.4.0 cmake:3.10.2
Linux scw-eloquent-tereshkova 4.9.93-mainline-rev1 #1 SMP Tue Apr 10 09:54:46 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux
ERROR: mysql installation failed.
安装失败,请截图以上报错信息发帖至论坛www.bt.cn/bbs求助
