JAY because of no certificate installed iam not able to access to panel via hostname but you should enable ip too if you block for IP access then in case if we dont have access to ssh then it will be problem
aaPanel_Jose JAY You can open panelssl and we will automatically generate a certificate for you. After the domain name is bound to the panel, you can't access the panel through ip, but ssh will not be affected. Of course, your domain name must first resolve a record to the bound machine.
JAY LOL I have done all those already before changing to domain cp is not issue self sing certificate to cp.domain.com NET::ERR_CERT_AUTHORITY_INVALID
JAY if iam under CF cp.domain.com/8888 will never open as port 8888 is blocked https://support.cloudflare.com/hc/en-us/articles/200169156-Which-ports-will-Cloudflare-work-with- how can i install letsencrypt SSL to cp.domain.com
JAY after new update now if i access panel via domain name like cp.domain.com it opens site earlier it redirects to panel now i need to type cp.domain.com:port ..
aaPanel_Jose JAY You must enter the panel port to log in to the panel. The panel does not automatically redirect. Please check if the browser automatically fills in the port when you enter the domain name.
Kisku aaPanel_Jose I've enabled panel ssl without further knowledge about it. Now I myself can't access the panel with ip. Please help me out.
Kisku aaPanel_Jose aaPanel_Jose I've enabled panel ssl without further knowledge about it. Now I myself can't access the panel with ip. Please help me out.
