sankalpart Hi, I found this aaPanel is very useful and cool ! i recently install wordpress i have found 2 issue at the same time **1. only home page is working rest are showing " 404 Not Found nginx " error i have read one of the form solution but i am not sure where to put that code to resolve it? I have 2 domain but when i am installing wordpress on 2nd domain its opens 1st domain website " how to resolve this?"** Pls guide me as fast as possible . Thanks in advance regards
ViperBlood If you restoring the website on 2 domain, then delete the .htaccess file and create a new one. It's solved my problem
Stealth I have too this problem with Wordpress, this will help I think: https://www.aapanel.com/forum/d/1289-404-not-found-nginx/2 But not tried yet, I hate Nginx. Apache is best solution for me (max with Nginx proxy)
dotrungquan I have completed the fix and have rewritten the document Link: https://dotrungquan.info/huong-dan-fix-loi-404-aapanel-don-gian/
aaP_martinko.m.2005 It still doesn't work for me, I don't have a wordpress but a php application. The homepage works, but as soon as I go to another page, I get the error.
aaPanel_Kern Starinenko Hi, is it possible to try to refer to this? Please check whether your url rewrite has the following configuration, if not, please add it and try to access again https://www.aapanel.com/forum/d/1289-404-not-found-nginx/2
aaPanel_Kern aaP_ngbaze100 Check what the website's logs show. 404 is the file not found. Is the url rewirte set?
