aaPanel_Kern 025-02-24T00:57:45.403279Z 52423 [Warning] IP address '194.187.176.246' could not be resolved: Name or service not known
2025-02-24T01:18:58.606587Z 52487 [Warning] IP address '8.221.139.48' could not be resolved: Name or service not known
2025-02-24T02:30:13.309978Z 52763 [Warning] IP address '35.240.60.92' has been resolved to the host name '92.60.240.35.bc.googleusercontent.com', which resembles IPv4-address itself.
2025-02-24T02:48:02.529925Z 52821 [Warning] IP address '198.235.24.167' could not be resolved: Name or service not known
2025-02-24T03:08:29.083185Z 52899 [Warning] IP address '147.45.112.181' could not be resolved: Name or service not known
2025-02-24T03:14:41.753546Z 52923 [Warning] IP address '146.70.132.248' could not be resolved: Name or service not known
2025-02-24T03:51:14.596664Z 53078 [Note] Got an error reading communication packets
2025-02-24T03:51:14.622200Z 53079 [Note] Got an error reading communication packets
2025-02-24T03:51:27.355839Z 53080 [Note] Got an error reading communication packets
2025-02-24T03:51:27.372571Z 53081 [Note] Got an error reading communication packets
2025-02-24T03:51:28.374959Z 53082 [Note] Got an error reading communication packets
2025-02-24T03:51:28.404795Z 53083 [Note] Got an error reading communication packets
2025-02-24T04:06:50.661752Z 0 [Note] Giving 3 client threads a chance to die gracefully
2025-02-24T04:06:50.662068Z 0 [Note] Shutting down slave threads
2025-02-24T04:06:52.664656Z 0 [Note] Forcefully disconnecting 3 remaining clients
2025-02-24T04:06:52.664765Z 0 [Warning] /www/server/mysql/bin/mysqld: Forcing close of thread 51867 user: 'sql_apiqiyou_baj'
2025-02-24T04:06:52.664939Z 0 [Warning] /www/server/mysql/bin/mysqld: Forcing close of thread 51987 user: 'sql_apiqiyou_baj'
2025-02-24T04:06:52.665099Z 0 [Warning] /www/server/mysql/bin/mysqld: Forcing close of thread 52996 user: 'sql_apiqiyou_baj'
2025-02-24T04:06:52.670190Z 0 [Note] Event Scheduler: Purging the queue. 0 events
2025-02-24T04:06:52.682118Z 0 [Note] Binlog end
2025-02-24T04:06:52.809246Z 0 [Note] Shutting down plugin 'ngram'
2025-02-24T04:06:52.810120Z 0 [Note] Shutting down plugin 'partition'
2025-02-24T04:06:52.810150Z 0 [Note] Shutting down plugin 'BLACKHOLE'
2025-02-24T04:06:52.810189Z 0 [Note] Shutting down plugin 'ARCHIVE'
2025-02-24T04:06:52.810204Z 0 [Note] Shutting down plugin 'PERFORMANCE_SCHEMA'
2025-02-24T04:06:52.811339Z 0 [Note] Shutting down plugin 'MRG_MYISAM'
2025-02-24T04:06:52.811389Z 0 [Note] Shutting down plugin 'MyISAM'
2025-02-24T04:06:52.811469Z 0 [Note] Shutting down plugin 'INNODB_SYS_VIRTUAL'
2025-02-24T04:06:52.812564Z 0 [Note] Shutting down plugin 'INNODB_SYS_DATAFILES'
2025-02-24T04:06:52.812589Z 0 [Note] Shutting down plugin 'INNODB_SYS_TABLESPACES'
2025-02-24T04:06:52.812601Z 0 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN_COLS'
2025-02-24T04:06:52.812613Z 0 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN'
2025-02-24T04:06:52.812623Z 0 [Note] Shutting down plugin 'INNODB_SYS_FIELDS'
2025-02-24T04:06:52.812632Z 0 [Note] Shutting down plugin 'INNODB_SYS_COLUMNS'
2025-02-24T04:06:52.812641Z 0 [Note] Shutting down plugin 'INNODB_SYS_INDEXES'
2025-02-24T04:06:52.812650Z 0 [Note] Shutting down plugin 'INNODB_SYS_TABLESTATS'
2025-02-24T04:06:52.812662Z 0 [Note] Shutting down plugin 'INNODB_SYS_TABLES'
2025-02-24T04:06:52.812674Z 0 [Note] Shutting down plugin 'INNODB_FT_INDEX_TABLE'
2025-02-24T04:06:52.812683Z 0 [Note] Shutting down plugin 'INNODB_FT_INDEX_CACHE'
2025-02-24T04:06:52.812693Z 0 [Note] Shutting down plugin 'INNODB_FT_CONFIG'
2025-02-24T04:06:52.812703Z 0 [Note] Shutting down plugin 'INNODB_FT_BEING_DELETED'
2025-02-24T04:06:52.812727Z 0 [Note] Shutting down plugin 'INNODB_FT_DELETED'
2025-02-24T04:06:52.812740Z 0 [Note] Shutting down plugin 'INNODB_FT_DEFAULT_STOPWORD'
2025-02-24T04:06:52.812750Z 0 [Note] Shutting down plugin 'INNODB_METRICS'
2025-02-24T04:06:52.812756Z 0 [Note] Shutting down plugin 'INNODB_TEMP_TABLE_INFO'
2025-02-24T04:06:52.812761Z 0 [Note] Shutting down plugin 'INNODB_BUFFER_POOL_STATS'
2025-02-24T04:06:52.812766Z 0 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE_LRU'
2025-02-24T04:06:52.812771Z 0 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE'
2025-02-24T04:06:52.812776Z 0 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX_RESET'
2025-02-24T04:06:52.812781Z 0 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX'
2025-02-24T04:06:52.812785Z 0 [Note] Shutting down plugin 'INNODB_CMPMEM_RESET'
2025-02-24T04:06:52.812790Z 0 [Note] Shutting down plugin 'INNODB_CMPMEM'
2025-02-24T04:06:52.812794Z 0 [Note] Shutting down plugin 'INNODB_CMP_RESET'
2025-02-24T04:06:52.812799Z 0 [Note] Shutting down plugin 'INNODB_CMP'
2025-02-24T04:06:52.812804Z 0 [Note] Shutting down plugin 'INNODB_LOCK_WAITS'
2025-02-24T04:06:52.812808Z 0 [Note] Shutting down plugin 'INNODB_LOCKS'
2025-02-24T04:06:52.812813Z 0 [Note] Shutting down plugin 'INNODB_TRX'
2025-02-24T04:06:52.812825Z 0 [Note] Shutting down plugin 'InnoDB'
2025-02-24T04:06:52.818014Z 0 [Note] InnoDB: FTS optimize thread exiting.
2025-02-24T04:06:52.818969Z 0 [Note] InnoDB: Starting shutdown...
2025-02-24T04:06:52.922105Z 0 [Note] InnoDB: Dumping buffer pool(s) to /www/server/data/ib_buffer_pool
2025-02-24T04:06:52.923056Z 0 [Note] InnoDB: Buffer pool(s) dump completed at 250224 12:06:52
2025-02-24T04:06:53.517723Z 0 [Note] InnoDB: Shutdown completed; log sequence number 33963986
2025-02-24T04:06:53.518767Z 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
2025-02-24T04:06:53.518804Z 0 [Note] Shutting down plugin 'MEMORY'
2025-02-24T04:06:53.518815Z 0 [Note] Shutting down plugin 'CSV'
2025-02-24T04:06:53.518835Z 0 [Note] Shutting down plugin 'sha256_password'
2025-02-24T04:06:53.518842Z 0 [Note] Shutting down plugin 'mysql_native_password'
2025-02-24T04:06:53.519098Z 0 [Note] Shutting down plugin 'binlog'
2025-02-24T04:06:53.526391Z 0 [Note] /www/server/mysql/bin/mysqld: Shutdown complete
2025-02-24T04:06:55.081314Z 0 [Warning] 'NO_ZERO_DATE', 'NO_ZERO_IN_DATE' and 'ERROR_FOR_DIVISION_BY_ZERO' sql modes should be used with strict mode. They will be merged with strict mode in a future release.
2025-02-24T04:06:55.081597Z 0 [Warning] 'NO_AUTO_CREATE_USER' sql mode was not set.
2025-02-24T04:06:55.081714Z 0 [Note] --secure-file-priv is set to NULL. Operations related to importing and exporting data are disabled
2025-02-24T04:06:55.086264Z 0 [Note] /www/server/mysql/bin/mysqld (mysqld 5.7.44-log) starting as process 1764569 ...
2025-02-24T04:06:55.130148Z 0 [Note] InnoDB: PUNCH HOLE support available
2025-02-24T04:06:55.130237Z 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2025-02-24T04:06:55.130254Z 0 [Note] InnoDB: Uses event mutexes
2025-02-24T04:06:55.130270Z 0 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
2025-02-24T04:06:55.130285Z 0 [Note] InnoDB: Compressed tables use zlib 1.2.13
2025-02-24T04:06:55.131562Z 0 [Note] InnoDB: Number of pools: 1
2025-02-24T04:06:55.131899Z 0 [Note] InnoDB: Using CPU crc32 instructions
2025-02-24T04:06:55.136853Z 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2025-02-24T04:06:55.165295Z 0 [Note] InnoDB: Completed initialization of buffer pool
2025-02-24T04:06:55.171199Z 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2025-02-24T04:06:55.194931Z 0 [Note] InnoDB: Highest supported file format is Barracuda.
2025-02-24T04:06:55.247700Z 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2025-02-24T04:06:55.247827Z 0 [Note] InnoDB: Setting file '/www/server/data/ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2025-02-24T04:06:55.310713Z 0 [Note] InnoDB: File '/www/server/data/ibtmp1' size is now 12 MB.
2025-02-24T04:06:55.311461Z 0 [Note] InnoDB: 96 redo rollback segment(s) found. 96 redo rollback segment(s) are active.
2025-02-24T04:06:55.311481Z 0 [Note] InnoDB: 32 non-redo rollback segment(s) are active.
2025-02-24T04:06:55.312620Z 0 [Note] InnoDB: 5.7.44 started; log sequence number 33963986
2025-02-24T04:06:55.313527Z 0 [Note] Plugin 'FEDERATED' is disabled.
2025-02-24T04:06:55.314194Z 0 [Note] InnoDB: Loading buffer pool(s) from /www/server/data/ib_buffer_pool
2025-02-24T04:06:55.360268Z 0 [Note] InnoDB: Buffer pool(s) load completed at 250224 12:06:55
2025-02-24T04:06:55.434785Z 0 [Note] Found ca.pem, server-cert.pem and server-key.pem in data directory. Trying to enable SSL support using them.
2025-02-24T04:06:55.434836Z 0 [Note] Skipping generation of SSL certificates as certificate files are present in data directory.
2025-02-24T04:06:55.434851Z 0 [Warning] A deprecated TLS version TLSv1 is enabled. Please use TLSv1.2 or higher.
2025-02-24T04:06:55.434934Z 0 [Warning] A deprecated TLS version TLSv1.1 is enabled. Please use TLSv1.2 or higher.
2025-02-24T04:06:55.443825Z 0 [Warning] CA certificate ca.pem is self signed.
2025-02-24T04:06:55.443950Z 0 [Note] Skipping generation of RSA key pair as key files are present in data directory.
2025-02-24T04:06:55.445573Z 0 [Note] Server hostname (bind-address): '*'; port: 3306
2025-02-24T04:06:55.446125Z 0 [Note] IPv6 is available.
2025-02-24T04:06:55.446504Z 0 [Note] - '::' resolves to '::';
2025-02-24T04:06:55.446543Z 0 [Note] Server socket created on IP: '::'.
2025-02-24T04:06:55.471548Z 0 [Note] Failed to start slave threads for channel ''
2025-02-24T04:06:55.511027Z 0 [Note] Event Scheduler: Loaded 0 events
2025-02-24T04:06:55.511666Z 0 [Note] /www/server/mysql/bin/mysqld: ready for connections.
Version: '5.7.44-log' socket: '/tmp/mysql.sock' port: 3306 Source distribution
