yclywz41 Hello, I have installed mongodb extension from php 7.3 Install extension section but it says mongodb NO in php info database-driven section. When I try to connect with php, it does not.
yclywz41 aaPanel_Jose If the problem is resolved, it makes a comeback if you know it would be great thank you good work
yclywz41 aaPanel_Jose When I start updating 7.3 it gets stuck here. It is not uninstalled. I fixed the panel but nothing is done. Would you check?
aaPanel_Jose yclywz41 It actually works in the background, but the logs are not shown, we will fix this problem as soon as possible
yclywz41 aaPanel_Jose I don't know if the update is done or not, you say it doesn't work in the background, but in the database-driven part, mongodb is still not installed.
aaPanel_Jose yclywz41 Your screenshot exposes your ip, I deleted it, after fixing the panel, it can solve the problem of updating php log stuck
