aaPanel_Jose aaP_alondolinski Please try reinstalling both modules btpip install -I gevent btpip install -I psutil bt restart
aaPanel_Jose aaP_alondolinski It may be that there is a problem with your local ca, try to specify an http source for installation btpip install -i http://pypi.douban.com/simple/ psutil btpip install -i http://pypi.douban.com/simple/ gevent
aaPanel_Captain aaP_alondolinski Could you please provide the login information of the server? I will check the machine mail:captain@aapanel.com
aaPanel_Captain aaP_alondolinski Hello, I don't quite understand your reply. Can't you provide the login information of the server
aaP_alondolinski aaPanel_Captain i can provide it i want to do it on discord if you not using discord i will send it to your mail
aaP_alondolinski aaPanel_Captain let me know please if any news as i said in the mail pay attention please there is more services running so do not reboot or reinstall the machine!!!
aaPanel_Captain aaP_alondolinski We will not restart the user's machine. If necessary, we will confirm with you
aaPanel_Captain aaP_alondolinski Dbian 8 is not supported. You are advised to use Debian 10 or later. Change the server password at the same time
