Free Good morning last night at 8 pm I received this error on the server which is written in the title do you have any idea what it might be?
aaPanel_Kern Free Hello, it shows that the /tmp/php-cgi-74.sock resource cannot be used. Have you started php7.4? You can check it in the app store. If you start it, check if there is an error. If not, please restart php7.4
Free aaPanel_Kern Thanks for the answer, php version 7.4 is installed from the beginning on the server with nginx
aaPanel_Kern Free Hi, is it working normally? If it can be used normally, it can be ignored. If you want to modify it, you can change it here. If you want to modify the configuration file, you must make a backup first.
Free Last night my site on wordpress was attacked on GET and POST for the future how can i block such attacks you know somehow
