ardhiyasa11 Hi, how do I move the index file from var/www/html/ to www/wwwroot? the problem is that the files indexed on my web are from the var/www/html directory
aaPanel_Kern ardhiyasa11 Hello, try copying the /var/www/html directory to /www/wwwroot/you_domain_name directly on the Files screen
aaPanel_Kern ardhiyasa11 Hello, this depends on the root directory of the site. Which is the root directory and which is the directory of the index file
ardhiyasa11 aaPanel_Kern my site's root directory is at www/wwwroot/domain.com but I try to create the file but it doesn't show up on my site. when I create in var/www/html the file is indexed in the site.
aaPanel_Kern ardhiyasa11 This indicates that there are other web services in your operating system. Use the command to check Panel installed web program at /www/server ps aux|grep -E "nginx|apache|http"
aaPanel_Kern ardhiyasa11 Apache is running in your system and uses port 80, so it is not a service provided by the web program installed by aapanel. Did you install it yourself? Use the non panel installed Apache. However, the panel cannot be managed Delete the non panel installed Apache. Use the panel installed Apache
aaPanel_Kern Hello, is the problem solved? Please check which program is using this port? If so, remove? aaP_faihz.orgadox
aaP_faihz.orgadox still not finished. So like this, I have a server on which Apache seems to be installed and there is a website running on it. When I installed Aapanel the website couldn't be accessed. Do I have to uninstall the old Apache? @aaPanel_Kern
aaPanel_Kern Hello, yes, if you have installed apache in other ways, it will not be possible to install software using apanel aaP_faihz.orgadox
