aaP_joklin12 I can't run mariadb mysql service 10.11.6. what I have tried but always fails: 1. install uninstall mysql 2. clear the cache panel 3. update aapanel, fix and restart 4. restart and shutdown Ubuntu OS Please help me
Brain Hello, help please guys My aaPanel is not accessible, I have restarted and the BT status is also running Please help
aaPanel_Kern Hello, What information is not accessible? Can you execute the command to check? curl -k https://www.aapanel.com/script/aapanel_check.sh | bash Brain
mindzor hello admin. is this was normal? i have some vps installed with aapanel. but the folder size of /server are different. the biggest/largest size was : 36.60 GB while my other vps just around 10-15 GB
aaPanel_Kern Hello, This requires the specific directory size, and different software and data will determine the size. mindzor
Brain aaPanel v7.0.20 I want to change the website file, but I can't save it, because I have to fill in the project name, but the name field can't be filled in, like it's disabled. help please
aaPanel_Kern Can't click the box? Is there any special symbols or the like in the project name? Brain
aaP_support194 Hello, after I clicked sql sync and I checked again, all my data was lost, how can I restore it?
aaPanel_Kern Whether there are databases and tables in PHPmyadmin. Can the table be opened normally? Please explain in detail Is it normal to click to get from the server? aaP_support194
aaP_letinspire.com Had this problem before. Clicking Get DB from server fixed it for me. Just make sure to backup first
aaP_tunnaduong hello @aaPanel_Kern, i just updated my panel to latest version, after that i reload the page, 404 appeared, i entered the panel entrance too but still 404
aaPanel_Kern Hello, please check whether you use the correct address to access, you can use this command to check: bt 14 aaP_tunnaduong
