aaPanel_Kern arsse Hello, the log shows "SASL LOGIN authentication failed", please check whether the user name and password are correct. SSL not working Is the system Debian 11? Debian11 we have not done related compatibility
arsse "the log shows "SASL LOGIN authentication failed", please check whether the user name and password are correct." which user and password?
aaPanel_Kern arsse Hi, what version of centos are you using? This problem has not been reproduced in testing. User and password for email used in PHP mail() or sendmail
arsse aaPanel_Kern User and password for email used in PHP mail() or sendmail I know php mail() and sendmail has not user/password. If mail server of aapanel need a global user/pass or need dovecot or postfix set settings for sending by php mail() or sendmail() tell me i setup.
aaPanel_Kern arsse Hi. After installing the mail server, if there is no error, you need to create a user to send mail. Username and Password Fill in the username and password of the user you created smtp, pop/imap fill in your server ip or domain
arsse aaPanel_Kern Hi. After installing the mail server, if there is no error, you need to create a user to send mail. Username and Password Fill in the username and password of the user you created smtp, pop/imap fill in your server ip or domain Hi. Email that send by SMTP in CMS like wordpress good works. But what must i do for good sending emails by php mail()? Also why SSL has that problem that i uploaded picturs?
aaPanel_Kern arsse Hello, the problem of php mail() you can use search engine query What SSL has your uploaded images?
aaPanel_Kern arsse Hi, does trying to execute the command fix it? btpip install --upgrade pyOpenSSL bt reload
