i installed redis extension via panel but it doesnt work
i checked the configuration file but it seemed nothing wrong
and the service started successfully
please help
full logs below
[18-May-2022 14:41:11] NOTICE: fpm is running, pid 505503
[18-May-2022 14:41:11] NOTICE: ready to handle connections
[01-Jun-2022 22:08:26] NOTICE: Terminating ...
[01-Jun-2022 22:08:26] NOTICE: exiting, bye-bye!
[12-Jun-2022 13:09:47] NOTICE: fpm is running, pid 150564
[12-Jun-2022 13:09:47] NOTICE: ready to handle connections
[12-Jun-2022 13:09:51] ERROR: Another FPM instance seems to already listen on /tmp/php-cgi-74.sock
[12-Jun-2022 13:09:51] ERROR: FPM initialization failed
[12-Jun-2022 13:10:32] NOTICE: Finishing ...
[12-Jun-2022 13:10:32] NOTICE: exiting, bye-bye!
[12-Jun-2022 13:10:33] NOTICE: fpm is running, pid 153065
[12-Jun-2022 13:10:33] NOTICE: ready to handle connections
[12-Jun-2022 13:12:34] NOTICE: Reloading in progress ...
[12-Jun-2022 13:12:34] NOTICE: reloading: execvp("/www/server/php/74/sbin/php-fpm", {"/www/server/php/74/sbin/php-fpm", "--daemonize", "--fpm-config", "/www/server/php/74/etc/php-fpm.conf", "--pid", "/www/server/php/74/var/run/php-fpm.pid"})
[12-Jun-2022 13:12:34] NOTICE: using inherited socket fd=7, "/tmp/php-cgi-74.sock"
[12-Jun-2022 13:12:34] ERROR: Another FPM instance seems to already listen on /tmp/php-cgi-74.sock
[12-Jun-2022 13:12:34] ERROR: FPM initialization failed
[12-Jun-2022 13:12:34] NOTICE: fpm is running, pid 156914
[12-Jun-2022 13:12:34] NOTICE: ready to handle connections
[12-Jun-2022 13:12:40] NOTICE: Reloading in progress ...
[12-Jun-2022 13:12:40] NOTICE: reloading: execvp("/www/server/php/74/sbin/php-fpm", {"/www/server/php/74/sbin/php-fpm", "--daemonize", "--fpm-config", "/www/server/php/74/etc/php-fpm.conf", "--pid", "/www/server/php/74/var/run/php-fpm.pid"})
[12-Jun-2022 13:12:40] NOTICE: using inherited socket fd=7, "/tmp/php-cgi-74.sock"
[12-Jun-2022 13:12:40] NOTICE: fpm is running, pid 157108
[12-Jun-2022 13:12:40] NOTICE: ready to handle connections
[12-Jun-2022 13:12:40] ERROR: Another FPM instance seems to already listen on /tmp/php-cgi-74.sock
[12-Jun-2022 13:12:40] ERROR: FPM initialization failed
[12-Jun-2022 13:12:45] NOTICE: Reloading in progress ...
[12-Jun-2022 13:12:45] NOTICE: reloading: execvp("/www/server/php/74/sbin/php-fpm", {"/www/server/php/74/sbin/php-fpm", "--daemonize", "--fpm-config", "/www/server/php/74/etc/php-fpm.conf", "--pid", "/www/server/php/74/var/run/php-fpm.pid"})
[12-Jun-2022 13:12:45] NOTICE: using inherited socket fd=7, "/tmp/php-cgi-74.sock"
[12-Jun-2022 13:12:45] NOTICE: fpm is running, pid 157305
[12-Jun-2022 13:12:45] NOTICE: ready to handle connections
[12-Jun-2022 13:12:45] ERROR: Another FPM instance seems to already listen on /tmp/php-cgi-74.sock
[12-Jun-2022 13:12:45] ERROR: FPM initialization failed
[12-Jun-2022 13:13:02] NOTICE: Reloading in progress ...
[12-Jun-2022 13:13:02] NOTICE: reloading: execvp("/www/server/php/74/sbin/php-fpm", {"/www/server/php/74/sbin/php-fpm", "--daemonize", "--fpm-config", "/www/server/php/74/etc/php-fpm.conf", "--pid", "/www/server/php/74/var/run/php-fpm.pid"})
[12-Jun-2022 13:13:02] NOTICE: using inherited socket fd=7, "/tmp/php-cgi-74.sock"
[12-Jun-2022 13:13:02] NOTICE: fpm is running, pid 160481
[12-Jun-2022 13:13:02] NOTICE: ready to handle connections
[12-Jun-2022 13:13:02] ERROR: Another FPM instance seems to already listen on /tmp/php-cgi-74.sock
[12-Jun-2022 13:13:02] ERROR: FPM initialization failed
[12-Jun-2022 13:14:57] NOTICE: Reloading in progress ...
[12-Jun-2022 13:14:57] NOTICE: reloading: execvp("/www/server/php/74/sbin/php-fpm", {"/www/server/php/74/sbin/php-fpm", "--daemonize", "--fpm-config", "/www/server/php/74/etc/php-fpm.conf", "--pid", "/www/server/php/74/var/run/php-fpm.pid"})
[12-Jun-2022 13:14:57] NOTICE: using inherited socket fd=7, "/tmp/php-cgi-74.sock"
[12-Jun-2022 13:14:57] NOTICE: fpm is running, pid 164362
[12-Jun-2022 13:14:57] NOTICE: ready to handle connections
[12-Jun-2022 15:06:34] NOTICE: Terminating ...
[12-Jun-2022 15:06:34] NOTICE: exiting, bye-bye!
[12-Jun-2022 15:06:58] NOTICE: fpm is running, pid 1245
[12-Jun-2022 15:06:58] NOTICE: ready to handle connections
[12-Jun-2022 15:30:01] NOTICE: Reloading in progress ...
[12-Jun-2022 15:30:01] NOTICE: reloading: execvp("/www/server/php/74/sbin/php-fpm", {"/www/server/php/74/sbin/php-fpm", "--daemonize", "--fpm-config", "/www/server/php/74/etc/php-fpm.conf", "--pid", "/www/server/php/74/var/run/php-fpm.pid"})
[12-Jun-2022 15:30:02] NOTICE: using inherited socket fd=7, "/tmp/php-cgi-74.sock"
[12-Jun-2022 15:30:02] NOTICE: fpm is running, pid 3219
[12-Jun-2022 15:30:02] NOTICE: ready to handle connections
[12-Jun-2022 15:35:51] NOTICE: Reloading in progress ...
[12-Jun-2022 15:35:51] NOTICE: reloading: execvp("/www/server/php/74/sbin/php-fpm", {"/www/server/php/74/sbin/php-fpm", "--daemonize", "--fpm-config", "/www/server/php/74/etc/php-fpm.conf", "--pid", "/www/server/php/74/var/run/php-fpm.pid"})
[12-Jun-2022 15:35:51] NOTICE: using inherited socket fd=7, "/tmp/php-cgi-74.sock"
[12-Jun-2022 15:35:51] NOTICE: fpm is running, pid 8130
[12-Jun-2022 15:35:51] NOTICE: ready to handle connections
[12-Jun-2022 16:00:02] NOTICE: Finishing ...
[12-Jun-2022 16:00:02] NOTICE: exiting, bye-bye!
[12-Jun-2022 16:00:03] NOTICE: fpm is running, pid 12116
[12-Jun-2022 16:00:03] NOTICE: ready to handle connections
[12-Jun-2022 16:04:01] NOTICE: Finishing ...
[12-Jun-2022 16:04:01] NOTICE: exiting, bye-bye!
[12-Jun-2022 16:04:02] NOTICE: fpm is running, pid 12243
[12-Jun-2022 16:04:02] NOTICE: ready to handle connections
[12-Jun-2022 16:05:59] NOTICE: Finishing ...
[12-Jun-2022 16:05:59] NOTICE: exiting, bye-bye!
[12-Jun-2022 16:06:00] NOTICE: fpm is running, pid 12298
[12-Jun-2022 16:06:00] NOTICE: ready to handle connections
[12-Jun-2022 16:13:26] NOTICE: Reloading in progress ...
[12-Jun-2022 16:13:26] NOTICE: reloading: execvp("/www/server/php/74/sbin/php-fpm", {"/www/server/php/74/sbin/php-fpm", "--daemonize", "--fpm-config", "/www/server/php/74/etc/php-fpm.conf", "--pid", "/www/server/php/74/var/run/php-fpm.pid"})
[12-Jun-2022 16:13:26] NOTICE: using inherited socket fd=7, "/tmp/php-cgi-74.sock"
[12-Jun-2022 16:13:26] NOTICE: fpm is running, pid 20468
[12-Jun-2022 16:13:26] NOTICE: ready to handle connections
[12-Jun-2022 16:15:39] NOTICE: Reloading in progress ...
[12-Jun-2022 16:15:39] NOTICE: reloading: execvp("/www/server/php/74/sbin/php-fpm", {"/www/server/php/74/sbin/php-fpm", "--daemonize", "--fpm-config", "/www/server/php/74/etc/php-fpm.conf", "--pid", "/www/server/php/74/var/run/php-fpm.pid"})
[12-Jun-2022 16:15:39] NOTICE: using inherited socket fd=7, "/tmp/php-cgi-74.sock"
[12-Jun-2022 16:15:39] NOTICE: fpm is running, pid 22766
[12-Jun-2022 16:15:39] NOTICE: ready to handle connections
[12-Jun-2022 16:24:55] NOTICE: Finishing ...
[12-Jun-2022 16:24:55] NOTICE: exiting, bye-bye!
[12-Jun-2022 16:24:56] NOTICE: fpm is running, pid 23575
[12-Jun-2022 16:24:56] NOTICE: ready to handle connections
